Civil 3D Forum
Lateral Pipe in Profile not Showing up
11 REPLIES 11
Message 1 of 12
doben
3361 Views, 11 Replies
I have created a pipe network and a couple of the manholes have laterals coming in at 90 degrees to the main line. I haven't been able to get these to show up in my profile views although they are listed in the manhole invert labels.
Any help is appreciated.
11 REPLIES 11
Message 2 of 12
Jeff_M
in reply to: doben
Make sure the Structure style is set to display the Structure Pipe Outlines in the Profile View Direction settings.
Message 3 of 12
doben
in reply to: Jeff_M
Hi Jeff,
Thanks for the response.
I discovered that I had "Enable Part Masking" checked. After unchecking the pipe displays. Now my mainline pipes extend into the manhole. (see attached).  I guess there's no way to display only the lateral pipe in the manhole.
BTW I'm using C3D 2012.
Message 4 of 12
Jeff_M
in reply to: doben
You should be able to use part masking (I do) and still see the lateral pipe.
Do you have the setting I mentioned in my first response set as I showed?
Message 5 of 12
in reply to: Jeff_M
I'm betting the OP intiated the "Draw Parts in Profile View" command and drew the laterals in the PV, rather than letting the manhole show them automatically using your technique. If so, take the laterals out of the profile view and let the manhole display them for you. In that manner you can use profile masking.
Message 6 of 12
doben
I did use "draw parts in profile view". I removed these as suggested they now display, however there is a 90 degree bend in the alignment and the pipes do not show up in this manhole if masking is on.
Is there another way?
Thanks.
Message 7 of 12
in reply to: doben
The lateral should still show up in the profile view, provided that it is connected to the manhole. Check to make sure the lateral shows up in the Structure properties Connected Pipes tab. Also, make sure the alignment PI is EXACTLY on the manhole's insertion point... sometimes that makes a difference. The last possibility is that the lateral pipe's invert is at some wildly erroneous elevation.
Also, run an Audit and see if the lateral pipe is, for some reason, bogus and gets erased.
Message 8 of 12
sjg
in reply to: doben
If I am understanding you correctly you just want to show the pipe entering the structure and not the pipe itself. Go into the profile view properties, pipe networks tab and next to the pipe in question make sure the Draw column is No. Once you set it to No, it should show up in the structure since your not drawing the actual pipe itself. Again make sure structure style in profile view has pipe outlines turned on.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Message 9 of 12
Jeff_M
in reply to: doben
Are you able to post the drawing, or a link to download it from?
Message 10 of 12
doben
in reply to: Jeff_M
Thanks for the help.  I created a new drawing and made a pipe network using the same styles. and everything displays as it should..
Message 11 of 12
in reply to: doben
I struggled with this problem for quite some time, thinking that it was a pipe style, then a profile view setting that was preventing my laterals from not showing up, but here was the problem, since I could not find anyone with a solution to this online.
Edit structure (not pipe)  style, under Display Tab, view direction set to Profile, ensure that 'Structure Pipe Outlines' is turned ON.
Message 12 of 12
Grimes_MG
If you followed sjg's suggestion (2 previous posts) you would have fond he provided the solution...
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
Rail Community
