AutoCAD Civil 3D General
musasalemi
Message 1 of 13 (1,019 Views)
Lat Long Conversion in Civil 3D Not Correct
1019 Views, 12 Replies
08-08-2012 09:59 PM
Hi All!
I was tried to convert a point from UTM-39N to Lat/Long using geodetic calculator; but when I checked the converted coordinates by another applications (like GeoLab); they were a little different (about two seconds) & I'm sure GeoLab is right. Any Help?
My settings and other information is attached.
Sorry for poor English
Thank you.
antoniovinci
Message 2 of 13 (1,013 Views)
Re: Lat Long Conversion in Civil 3D Not Correct
08-08-2012 11:00 PM in reply to: musasalemi
Try another way: first _MAPEXPORT it to a point shapefile in LL84, then _MAPIMPORT it back to check the precision.
musasalemi
Message 3 of 13 (1,005 Views)
08-09-2012 12:42 AM in reply to: antoniovinci
thanks, but unfortunately it doesn't work.
my question is why this had happened? :smileyindifferent:
antoniovinci
Message 4 of 13 (1,001 Views)
08-09-2012 12:46 AM in reply to: musasalemi
Please attach that UTM-39N point in DWG format, and paste here the expected LL84 coords, thanks.
musasalemi
Message 5 of 13 (993 Views)
08-09-2012 01:31 AM in reply to: antoniovinci
Expected latitude and longitude is:
 Lat: N27° 29' 53.196774"
 Long: E52° 38' 17.028054"
and what Civil3D give me is:
 Lat: N27° 29' 51.8162"
 Long: : E52° 38' 16.7578"
and the drawing that have the point is attached (Civil 3D 2012).
 thanks.
antoniovinci
Message 6 of 13 (987 Views)
08-09-2012 02:59 AM in reply to: musasalemi
Well, I tried to convert your EPSG:2059 point (X = 661811.296 , Y = 3042675.664) to EPSG:4326 (i.e. Lat-Long datum WGS84) with two different softwares, and here are my results.
1] Quantum Gis yields
LONG = 52.63811871
LAT = 27.49647281
2] Autocad Map2006 yields
LONG = 52.63815850
LAT = 27.49648261
then I calculated the HH'MM'SS' format here: http://www.earthpoint.us/Convert.aspx
The Qgis coords are: 27°29'47.3021", 052°38'17.2274"
The Autocad coords are: 27°29'47.3374", 052°38'17.3706"
As you can see, there's a LONG difference of 0.1432" and a LAT of 0.0353, yielding a 4 meters shift in LONG, and 1 meter in LAT.
Since two dfferent tools gave an almost identical result, I guess your expected coords Lat: N27° 29' 53.196774" Long: E52° 38' 17.028054" are simply wrong, sir.
musasalemi
Message 7 of 13 (934 Views)
Re: Lat Long Conversion in Civil 3D is Not Correct
08-09-2012 01:04 PM in reply to: antoniovinci
I work in an oil and gas company and I almost always have to convert Bench marks coords to lat/long or from lat/long coords. because of my job, the converted coords must have high accuracy (often 3mm) and when I use Geolab, I get this precision. I used to check Geolab with a high accuracy routine in MATLAB; so I trust Geolab. :smileyfrustrated:
Any Idea?
Thanks.
Message 8 of 13 (876 Views)
08-11-2012 09:56 AM in reply to: musasalemi
A pipeline must be within 3mm of accuracy horizontally...?  Wow.  Seems like major overkill to me.
Sinc
musasalemi
Message 9 of 13 (843 Views)
08-13-2012 03:21 AM in reply to: Sinc
Yes! I think pipe supports and their bolts, pipe equipments like boilers and etc. need that precision.
However I said I want that accuracy for the Bench marks!
Valued Contributor
Message 10 of 13 (811 Views)
08-13-2012 12:17 PM in reply to: musasalemi
Everybody is correct!
The problem is we are using different horizontal datums, in your autocad image you used the European Datum, but in the GeoLab you used WGS84.  I'm not sure what other people are using.  To check AutoCAD against GeoLab I used WGS84, the same that you used in GeoLab and the resultant coordinates matched, see below:
I STRONGLY suggest that you confirm what datum you are using.  People not understanding horizontal (and vertical) datums can lead to very costly mistakes.
As a PLS this is always something I fear, when people start converting coordinates I start getting phone calls at 2 in the morning.  I suggest you talk to your surveyor about your projects coordinate system, I'm sure they will tell you the same.
Mark
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
