AutoCAD Civil 3D General
Message 1 of 8 (1,406 Views)
Laptop Workstation Recommendations for C3d 2013
1406 Views, 7 Replies
01-11-2013 09:45 AM
I am on the hunt for a laptop workstation that will handle C3d 2013.  I realize there is a spec sheet listing requirements for the software, but thought someone might have some good advice/pros and cons on machines they are using.
AllenJessup
Message 2 of 8 (1,396 Views)
Re: Laptop Workstation Recommendations for C3d 2013
01-11-2013 10:49 AM in reply to: rsBria
Really depends on how much you want to spend. The usually advice is get the best you can afford. The usual top 2 for Civil are Memory and Processor Speed. There are some advantages with SSDs if you can afford one.
I've had a Sager in the past. My last laptop I got from the Dell Outlet site. A reconditioned M6500 for about 2 grand. It's been working great for the past couple of years.
Allen
sboon
Message 3 of 8 (1,368 Views)
01-11-2013 09:59 PM in reply to: AllenJessup
My laptop specs are part of my signature.  I've been running Civil 3d on it since 2010.  It's a heavy beast to carry around but I like it as a CAD system.
Valued Contributor
Message 4 of 8 (1,349 Views)
01-12-2013 10:06 AM in reply to: sboon
I use Civil 3D 2012 on a ASUS G73SW gaming laptop. Most of my grading work is in mountanous regions with massive surface data. Even though my graphics card is not supported by Autodesk, I am currently not having any problems. I had to adjust the video card setting slightly in the beginning.
ASUS G73SW
8 GB RAM
i7 processor 2630QM
64 bit window 7 (love it!)
NVIDIA GeForce GTX 460M with CUDA - 1GB video memory
700GB hard drive. Not sure of the manufacturer (this seems to be holding this laptop back).
I am looking into SSD, but I heard Civil 3D's temp files never truly delete on SSD drives and therefore will eventually fill the hard drive until it is disabled. Now... the source of this info is a great IT guy, but doesn't know much about Civil 3D, so take it as you will. I had a workstation that the SSD hard drive filled up to critical, in about 6 months. IT told me it was the way Civil 3D handles temporary and operating files.
Windows 7 64
Intel Core i7 2.0 GHz 2.0 GHz
8 GB RAM
Nvidia GeForce GTX460M
Civil 3D 2012 SP2.1
Jeff_M
Message 5 of 8 (1,346 Views)
01-12-2013 10:42 AM in reply to: d1of2
Change where Windows' TEMP folder is located. I did this by moving all of my USER files from the SSD to my data drive using a Symbolic link so everything thinks it is still on the C: but it is actually on my E: I've been using this laptop, with a 128gb SSD, without issue for 2+ years.
Message 6 of 8 (1,311 Views)
01-14-2013 10:55 AM in reply to: rsBria
Thanks for the input.
Valued Contributor
Message 7 of 8 (1,261 Views)
01-24-2013 12:27 PM in reply to: Jeff_M
thanks Jeff!
I was wondering how long it was going to take me to run into someone from the swamp! Gooday
Windows 7 64
8 GB RAM
Civil 3D 2012 SP2.1
Message 8 of 8 (1,206 Views)
02-01-2013 05:42 AM in reply to: rsBria
Thanks for all the input.  I went with a Toshiba X875Q7380, but it came with windows 8.  I am going to have to strip 8 off and install 7.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
