The problem is that LDD is not recognizing the name of your C3D profiles. It appears that LDD has zero flexibility in the naming convention for profiles. If you look at the xml file you'll probably see the profiles in there. You can solve the problem by editing the profile names in the xml file. I did it by exporting an alignment and profile from LDD, looking at the xml file, then editing the profile names in the xml that was exported from C3D. If you don't have at least a cursory knowledge of the xml data structure, it would probably be less time consuming to go into C3D, rename your profiles, and export again. Just make sure you are faithful to the LDD profile naming convention.
