Does anyone know where I would change the Bearing and Distance for the xml report so the calls have no space between the direction and the bearing.
Rick Jackson
Survey CAD Technician VI
Solved by Jeff_M. Go to Solution.
Looks like it is in the General_Formatting_JScript.xsl file:
function formatBearingDMS(angle) { // decimal degrees are E=0, N=90, W=180, S=270 (counter-clockwise) var angNum; if(angle >= 0 && angle <= 90) { angNum = 90. - angle; var bearing = formatAngleToDMS(angNum); return "N " + bearing + " E"; } else if(angle > 90 && angle <= 180) { angNum = angle - 90.; var bearing = formatAngleToDMS(angNum); return "N " + bearing + " W"; } else if(angle > 180 && angle < 270) { angNum = 270. - angle; var bearing = formatAngleToDMS(angNum); return "S " + bearing + " W"; } else { angNum = angle - 270.; var bearing = formatAngleToDMS(angNum); return "S " + bearing + " E"; } }
Remove the spaces from all of the Direction strings.
Thanks Jeff
Rick Jackson
Now to figure out why Win7 wont allow me to change the file since Im logged in as adminstrator
Rick Jackson
Jeff,
Would you know where I might find the formatting for the General Parcel Legal so the when the legal is run it doesn't but North 89degrees 54minutes 36seconds East.
What I'm looking for is to but space between the word degrees / minutes / seconds for the respective number.
Rick Jackson
Im using the Parcel - General Legal Description, I set the B&D to use the Degrees Minutes Seconds in the Report Settings, but I get this for the output
Notice how it smashes the d m s next to the number.
From the POINT OF BEGINNING; Thence, South 29degrees 17minutes 01seconds East for a distance of 6390.25 feet to a point on a line.
Thence, South 62degrees 40minutes 20seconds West for a distance of 521.36 feet to a point on a line.
Thence, South 59degrees 37minutes 27seconds West for a distance of 6155.18 feet to a point on a line.
Thence, South 60degrees 23minutes 21seconds West for a distance of 5029.98 feet to a point on a line.
Thence, North 29degrees 33minutes 39seconds West for a distance of 5294.96 feet to a point on a line.
Thence, North 60degrees 34minutes 38seconds East for a distance of 5287.29 feet to a point on a line.
Thence, North 29degrees 46minutes 15seconds West for a distance of 1179.98 feet to a point on a line.
thence North 60degrees 26minutes 33seconds East a distance of 6453.48 feet to the POINT OF BEGINNING;
Containing 69188070 square feet
Rick Jackson
OK, found it. I'm not familiar enough withopening XSL files in XMLNotepad to know why I cannot edit this in it, yet opeing in in basic Notepad allows it to be changed and correctly work....
These values are stored in the LegalDescriptions_Layout.xsl file:
function SetDirectionFormat(format)
dirFormat = format;
if(format == "Use °, ’, \”")
SetDirDegreeLabel("°");
SetDirMinuteLabel("'");
SetDirSecondLabel("\"");
else
SetDirDegreeLabel(" degrees");
SetDirMinuteLabel(" minutes");
SetDirSecondLabel(" seconds");
return format;
Note that I added a space to the beginning of each string and this is the output:
Thence, South 39 degrees 37 minutes 11.9 seconds West for a distance of 138.2405 feet to a point on a line.
Thence, North 90 degrees 00 minutes 00.0 seconds West for a distance of 18.4658 feet to a point on a line.
Rick Jackson
Jeff,
Thanks for the help, I ended up having to go into the report settings and reselecting the file General Parcel Legal xsl file, in report settings to get it to work, but did at last. Very strange, it seemed as though it was pointing to the correct file, just didn't have all the path information. have the %%DIR....... But once I browed to the correct file all was good.
I was also have the issue with the generally parsing, so the lines in the legal didn't change either, which lead me to that conclusions.
Rick Jackson
Jeff, would you happen to know how to remove the spaces inbetween the deg. min. sec. in the Legal Description_Layout.xsl?
The current end product is 0° 14' 15"
I desperatly need 0°14'15"
The General_Legal_Description_for_Parcels report writer uses the "Legal Description_Layout.xsl. Does the General_Legal_Description_for_Parcels report writer get its deg. min. sec. from some where else?
I have successfully changed the General_Formating_JScript.xsl which the Metes_and_Bounds report writer uses and the end product is correct but I need to use the General_Legal_Description_for_Parcels report writer because it will use a phrasing file that is more correct.
