Has anyone found a solution to this problem? When I try to open a LDD file with C3D, the file locks up and won't open. It appears to happen only when the LDD file has an alignment defined. Is anyone else having this issue?
I have had the problem with both Civil 3D 2011 and now with Civil 3D 2014. I have Civil 3D 2014 Hotfix 1 installed.
The only time I have issues is when the LDD drawing file contains links to alignment data.
Try this:
Open Land Desktop (if you still have it installed and use the RECOVER command to open the drawing you're having trouble with.
Then open C3D and attempt to open that file.
Or open C3D and just run the RECOVER command on the bad file.
Or INSERT the bad file into your C3D drawing.
Or type NEW in C3D and select the bad drawing as the template (you'll have to change the file it's looking for from DWT to DWG.
Or just copy and paste everything from the LDT drawing into the C3D file (assuming you can find some software to open it with).
I no longer have LDT loaded on any machines in my office but I have tried all of your other suggestions.
Thank you for the suggestions though.
