Civil 3D Forum
Land Desktop Files Crash When Opened in Civil 3D
8 REPLIES 8
Message 1 of 9
494 Views, 8 Replies
Has anyone found a solution to this problem?  When I try to open a LDD file with C3D, the file locks up and won't open.  It appears to happen only when the LDD file has an alignment defined.  Is anyone else having this issue?
8 REPLIES 8
Message 2 of 9
Jeff_M
Please include which version of C3D you are using, along with which, if any, Service Packs or hotfixes have been installed.
I have opened LDT drawings in C3D 2010-2013 without any issues that I can recall.
Message 3 of 9
in reply to: Jeff_M
I have had the problem with both Civil 3D 2011 and now with Civil 3D 2014.  I have Civil 3D 2014 Hotfix 1 installed.
The only time I have issues is when the LDD drawing file contains links to alignment data.
Message 4 of 9
mathewkol
Try this:
Open Land Desktop (if you still have it installed and use the RECOVER command to open the drawing you're having trouble with.
Then open C3D and attempt to open that file.
Or open C3D and just run the RECOVER command on the bad file.
Or INSERT the bad file into your C3D drawing.
Or type NEW in C3D and select the bad drawing as the template (you'll have to change the file it's looking for from DWT to DWG.
Or just copy and paste everything from the LDT drawing into the C3D file (assuming you can find some software to open it with).
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 5 of 9
Jeff_M
I just tested in 2014 and have no problem opening a LDT drawing which contains 3 alignments, 2 surfaces, a number of pipe runs and quite a few parcels.
Are you able to share one of these drawings for us to test for you?
Message 6 of 9
in reply to: mathewkol
I no longer have LDT loaded on any machines in my office but I have tried all of your other suggestions.
Thank you for the suggestions though.
Message 7 of 9
in reply to: Jeff_M
The files I have issues with are too large to post.  Could it have something to do with AEC objects?
Message 8 of 9
Jeff_M
AEC objects shouldn't bother it. If you'd like to email me a dwg I will take a look at it
jeffm AT quuxsoft DOT com
Message 9 of 9
Jeff_M
Well that drawing brought my laptop to a halt! After a reboot I started a new drawing and used Map to Query in all drawing objects and it now opens correctly.
Rail Community
