AutoCAD Civil 3D General Discussion
sgarmong
Message 1 of 4 (105 Views)
Lag working with points
105 Views, 3 Replies
02-04-2014 07:55 AM
I am experiencing a noticable lag (probably 30 seconds) when I go to Point Group properties (to change the display order of the point groups) and in the properties of individual point groups (to change point or label styles). I started noticing the problem around the time I installed a trial version of AutoDesk Vehicle Tracking. Anyone else having similar problems or possible fixes?
Valued Mentor
stacy.dunn
Message 2 of 4 (84 Views)
Re: Lag working with points
02-04-2014 10:27 AM in reply to: sgarmong
What version are you using?
If you are running 2011 with Raster Design, there is a bug with rollover tooltips and points.  Type ROLLOVERTIPS and set it to 0 and the delay should stop.
Stacy Dunn
sgarmong
Message 3 of 4 (78 Views)
02-04-2014 10:35 AM in reply to: sgarmong
I'm running Civil 3D 2014.
Checked the ROLLOVERTIPS but it was already set to 0.
*Expert Elite*
LeafRiders
Message 4 of 4 (41 Views)
03-20-2014 08:26 AM in reply to: sgarmong
Check your hardware acceleration and try tuning your settings. Also you may want to try and borrow your license if you're on a network license and see if that helps. I've heard of some network licensing lag issues and things have improved with a "Borrowed license".
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
