Civil 3D Forum
Labels seem to have shrunken.
1 REPLY 1
schroederC3D
129 Views, 1 Reply
It's as though the labels have lost their parametric link to the viewport scale or something. I created a viewport with a profile in it, with profile labels, grid text, etc. When I save and reopen the drawing, the labels are all tiny. But, if I copy the viewport to a different layout, they're fine again. Why would this be happening?
Thanks for your thoughts,
Andrew Schroeder
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
1 REPLY 1
schroederC3D
in reply to: schroederC3D
NM, from reading other posts on the board, I found that the layout print settings were set to 1:25.4..... So that was affecting the label display. I fixed it by setting to mm rather than inches and setting the scale to 1:1.
Andrew Schroeder
Reply Syntax?
Rail Community
