Civil 3D Forum
Labels not rebuilding
2 REPLIES 2
BrianD17
177 Views, 2 Replies
I opened a project that i had not been into for a month and for some reason the surface and labels will not rebuild automatically anymore.  Surface is set to rebuild automatic and i've gone in and changed the regenauto from on to off to on again, also rebooted the computer with no luck.  I have a combination of feature lines and points.  If I edit the elvations along the feature line the contours do not rebuild and the label does not change either.  If I hover over the elevation node in the feature line it will show the new elevation but the elevation label for that point does not reflect the change, neither do the contours.  If it is a point and I change it with the panorama window, the elevation tag will change but the contours do not rebuild until I tell it to rebuild.  Any slope labels going to that point do not update with it though.  Any thoughts?
thanks-
Brian
2 REPLIES 2
tcorey
in reply to: BrianD17
Your surface doesn't happen to be locked or on a locked layer?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
ccoles
Have you tried running an audit?
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Rail Community
