Sometimes, when I select a label doing pipe network if forever until the C3D finally release it.
Any idea ?
Hi ebarlevi-
Are you referring to a "lag" when selecting a pipe network label? If so do you have the Properties dialog open when you notice the lag? Try closing the Properties dialog and see if that helps.
That being said this is something Development is looking into, so if you notice the lag, please close the properties dialog when not in use and you should notice some improvement.
Hope this helps!
