Just taking a stab in the dark (didn't look at your lisp), perhaps you could
set your ucs to world, label, then reset your ucs?
Brian
C3D 2008
http://www.ctcivil.com
http://cadcafe.blogspot.com
wrote in message news:5698372@discussion.autodesk.com...
okay im using a lisp to label contours. this normally works great, ennter
the number you wont on the contour than then click where you want it, it
then inserts a wipeout box and a number over the top all aligned to the
contour. i have a survey file that has some kind or rotation to the ucs
because the labels just wont go on aligned to the contour. the wipeout is
aligned to the contour but the number is not. the lisp is attached. to use
type TIL and the M and then O, enter the number and
then click on the polyline
