Civil 3D Forum
Labelling 3D polyline with depth to surface on vertices.
7 REPLIES 7
Message 1 of 8
HansSMS
1334 Views, 7 Replies
Is there an efficient way of labelling up polygon vertices with an elevation difference to a surface? An example is to label up an underground service to indicate the depth below a design surface.
Hans Moller
Surveying & Management Services
Gladstone Australia
Metabox 16GB, Intel i7-9700K 3.6Ghz, 500GB SSD, 2TB HDD Nvidia GTX 1060
AutoCAD Civil 3D 2018
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: HansSMS
one way :make a surface from your polgon elevations , then a volume surface and  and labe the vertice referencing the volume surface
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 3 of 8
HansSMS
in reply to: Joe-Bouza
Thanks for the response. I was going that way but got put off by the point labels not ending up on the 3D polyline vertices but way below on the volume surface. But I do get one result I'm looking for: Sorting by elevation a list of points that do not have minimum depth.
Hans Moller
Gladstone Australia
Message 4 of 8
Cervino99
You could create a Line Label (for use on Featurelines etc) that make use of an Expression you have set up to calclulate the difference between two selected Surfaces.
That way you get the Labels on your vertices and you don't have to create a TIN Volume Surface
// O Cervin
Message 5 of 8
HansSMS
in reply to: Cervino99
Where would I create the expression that can get the surface elevations?
Hans Moller
Gladstone Australia
Message 6 of 8
Cervino99
Hi
Go to Toolspace - Settings.
General - Label Styles - Line - Expressions
Create your expression.
Create your Line Label and include the Expression you have made.
Use the Label on your Feature Line.
Annotate - Add Labels - Feature Line - Multiple Segments...
// Ove
Message 7 of 8
HansSMS
What I'm trying to say is I don't find a surface elevation:-
Hans Moller
Gladstone Australia
Message 8 of 8
Cervino99
Hi again,
I am sorry to have mislead you... 😕 This seems to only be available through the expression for Point Labels 😞
A not so great solution might be a heavy workaround.
- Create a TIN Volume Surface
- Create a Feature Line, draped to the Elevation of the TIN Volume Surface
- Create Labels (as discussed) using the Start Segment Z as value when creating the expression in the Label
Rail Community
