Civil 3D Forum
Labeling profile in degrees
6 REPLIES 6
jbokic
1145 Views, 6 Replies
Is there a way to label a profile tangent line in degrees instead of slope or rise/run?  I can't find an option for it using the default template styles.
6 REPLIES 6
peterfunkautodesk
in reply to: jbokic
There isn't a label in the default templates that does this, but if you make an Expression you can add that label. The expression you need is the Arc Tangent of the grade ATAN({Tangent Grade}) and return the value as an angle.
Cheers,
Peter Funk
Peter Funk
jbokic
in reply to: peterfunkautodesk
Sorry, forgot to update my posting.
That is what I ended up doing, although the final formula ended up as RAD2DEG(ATAN({Surface Slope})) to get the final result in degrees rather than radians.
Still, thanks for the response and the option to do this within the program.
peterfunkautodesk
in reply to: jbokic
If you set the return to be "Angle" instead of "Double" you shouldn't need to convert to degrees.
Cheers,
Peter Funk
Peter Funk
jbokic
True, and it does give me options for formatting in deg-min-sec.  Is there a way to have it display in decimal degrees instead?
peterfunkautodesk
in reply to: jbokic
By default "Angle" will format in decimal degrees.
Peter Funk
Peter Funk
jbokic
Well that was silly of me, thank you!
Rail Community
