Civil 3D Forum
Labeling azimut in aligments
5 REPLIES 5
1991 Views, 5 Replies
Hi friends:
I would like to know if Autocad Civil 3D can label the azimut angle in an aligment. For example, i need to know the azimuth angle in different progresive points like 1+250, 7+325, 10+500, etc. each point can be in tangent or curve, it would be helful if all azimut angles could be exported to excell file, maybe a lisp aplication.
Sorry for the bad english, i hope you can understand wath i want.
Thank you so much.
ACM
5 REPLIES 5
AllenJessup
If you're talking about an Azimuth label. An Azimuth (or Bearing) describes the direction of a line. You can label the Azimuth of the lines (Tangents) in the alignment. But the only Azimuths you can label in a curve are the radials.
What are you trying to show or export?
Allen Jessup
CAD Manager - Designer
in reply to: AllenJessup
For example, i have some stations in an aligment where we will project a culvert and i think could be helpful to know the azimuth angle in these stations in order to put a culvert block with skew angle automatically with excel something like scrip based in the azimuth angle. I attached a picture to explain it.
AllenJessup
In the example on the straight section of the alignment. Labeling the Azimuth of the alignment will give you the angle. When on the curve, there isn't any automatic way to label the tangent at that point. In 2013 you can label a "line" by points. So you might be able to create an expression that would take an Azimuth from the radius pt to the station point and add 90°.
As far as a report goes. You might be able to do something similar to the label. But I haven't done anything above some basic modification to the existing report style. So someone with more experience with them would have to comment.
Allen
Allen Jessup
The Station Offset Label can label the "Instantaneous Direction" in the label. You could make one of these labels and use an offset of 0 if you wanted it right on the alignment.
Cheers,
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
in reply to: peterfunkautodesk
You are right Peter, i created a new label using "instantaneous direction" with measurement type = north azimuth and it works, thats wath i wanted!!. I would like to export the labels to excel but no problem whith the instantaneous direction is enough. Thank you very much.
Rail Community
