AutoCAD Civil 3D General
Distinguished Contributor
pocketmerlin
Message 1 of 6 (214 Views)
Labeling all of a surface's contours at once?
214 Views, 5 Replies
11-06-2013 10:58 AM
Often I've found myself dealing with some pretty complicated surfaces that have a lot of nooks and crannies, and many of the contour lines are only in a corner of the surface or are small and closed, and thus when I find myself wanting to have contour labels on all of the contours, there's not really one line I can draw using the "Create Multiple Labels at Interval" option to ensure that every contour is labeled. Thus I end up doing "Create Multiple At Interval" with a few different lines intersecting contours, but I often end up hitting some of the contours multiple times and I get a mess of labels.
I haven't been able to find a way to automatically just multiple labels on all of the contours at an interval in one fell swoop, so I started trying to program one...but then I got stuck with that, too.
Does anyone know of a built-in method of doing what I want to do, or do I need to continue pursuing a programmatic solution?
Thanks!
Neilw
Message 2 of 6 (210 Views)
Re: Labeling all of a surface's contours at once?
11-06-2013 11:02 AM in reply to: pocketmerlin
I submitted a wish for that ability some time ago. For now you'll have to resort to workarounds.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
jmayo
Message 3 of 6 (173 Views)
11-06-2013 12:41 PM in reply to: pocketmerlin
One other unfortunate thing to note is that the Contour at Interval command can place a LOT of labels in a file and this can degrade performance.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
neilyj
Message 4 of 6 (165 Views)
11-06-2013 12:52 PM in reply to: jmayo
Yes I certainly agree with this - do you need to label all contours or could you just selectively use spot levels instead and the user can deduce the contour value knowing the interval?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
christopher
Message 5 of 6 (159 Views)
11-06-2013 01:09 PM in reply to: pocketmerlin
Did you happen to see this post I did a while back? http://blog.civil3dreminders.com/2009/11/mass-label-contours.html
It should be all of the code you need to accomplish the task. It could even be optimized/or changed to work better with the current API. I was sending the command to the command line instead of using the API to add the labels, which wasn't available at the time I did the post.
Neilw
Message 6 of 6 (155 Views)
11-06-2013 01:13 PM in reply to: jmayo
One of the big downsides to applying labels at intervals is it creates many short contour label lines in the drawing. If you then change the contour interval of the surface style, many of those labels don't hit any more and it is a tedious process to fix. The whole contour label line paradigm is flawed for this scenario.
My wish is for the option to apply a label interval to the surface style itself and have them automatic and dynamic. Ideally it would also be able to resolve label conflicts such as in GIS.
WIN 7 64 PRO
RADEON 6450, 1 GB
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
