Using the Best Practices, different components in their own DWG files, all brought together in a production sheet where I can place the labeling for that sheet. I can add labels for Surfaces, Alignments, Pipe networks, through the Xref(s). Evidently this was not extended to Intersection Objects.
What I'm doing now is creating a new Intersection at each street intersection just so I can get a label which shows the station of each alignment at the intersection. Is there a better way to do this?
Solved by Lisa_Pohlmeyer. Go to Solution.
Thanks, Lisa. That's what I have always used until the Intersection was introduced. Just trying to utilize the Intersection Objects since they already are a part of the model.
And, yes, it took me this long to figure out that the 'new' workflow won't work as expected...first job to get to this stage of development in more than 2 years.
