Dave,
When I first saw this in C3D, I immediately saw the potential in vanilla
AutoCAD. Add my tuppence worth (I'm in the UK - no cents here) to the list
of requesters for this functionality in vanilla AutoCAD.
Cheers,
Adam
Adam Davis
Wish Software Limited
5 Biggar Road
Silverburn
EH26 9LQ
UK
tel: +44 (0)1968 670 899
fax: +44 (0)870 220 0875
mailto:adam@wishsoftware.com
www.wishsoftware.com
"Dave Simeone" wrote in message
news:402c1e2d_2@newsprd01...
> Hi all - Note that we've shared this request with the core AutoCAD team.
It
> would definitely make sense if all text in a drawing had the same scaling
> and orientation behavior.
> No promises!
> Thanks
> Dave S
> "Jon Rizzo" wrote in message
> news:40290ae4_2@newsprd01...
> > Hi Marco,
> > That kind of defeats the purpose. Labels have a bit more intelligence
> than
> > ordinary MText strings, such as the ability to automatically adjust to
the
> > current viewport twist & scale. If you want, you can use the "export to
> > autocad" command to create exploded mtext objects (and exploded
everything
> > else, too).
> > Jon Rizzo
> > Langan Engineering and Environmental Services, Inc.
> > "MHerranz" wrote in message
> > news:3109156.1076428411947.JavaMail.jive@jiveforum2.autodesk.com...
> > > I've just installed C3D because I heard about the label utility. I can
> see
> > enormous potential timesaving here!
> > > My question is: Is there a workaround to make it generate a simple
Mtext
> > string?
> > > Thanks in advance,
> > > Marco
