Show only
Search instead for
Is there a way to label single lines and arcs with bearing, distance, etc.
without it being defined as a parcel? I have boundarys defined as parcels
and they label fine. I need to label section lines, and partial line/arc
segments within the parcel.
I'm new to this Civil 3D and I'm in the middel of trying to label only a line. Is there a quick meathod to this "single line into a parcel segment and label it."
Tim Grant Civil 3D 2022.1.3 Windows 10 Professional Intel Core i7-10700 CPU @ 2.9 GHz 16 GB, 64-bit
Not that I've seen or heard of. This came into play recently while I was trying to put together a filing plat for a subdivision. There are labeling requirements here that C3D just can't handle yet so I took the drawing back into LDD and label the lines. It works fine for now but I know that the C3D folks have heard about this and are aware of the problem.
