Civil 3D Forum
Label missing (Need help ASAP)
3 REPLIES 3
525 Views, 3 Replies
We are working on a file here and the lables on the drawing are missing.  We had station offset lables in our drawings and are now missing from the plans.  Any suggesting would be great.
3 REPLIES 3
tcorey
Select your alignment, right click, select Edit Alignment labels. At the bottom of the dialog you can select to load an alignment label group or you can select individual label styles for various alignment parts using the options toward the top of the screen.
Other possibilities: Check your layers, maybe something was frozen? Check your CANNOSCALE. Maybe it's set so low that labels don't display? Check the labels styles that are applied and be sure the components are set to visible on the layout tab and that the entire label is set to visible on the general tab.
If you post your drawing someone can look at it and probably answer your problem in three minutes or less.
One last possibility: corruption. I went back and forth with a fellow last week on a cogo labeling issue and it ended up that his labels would not display, even though he was doing everything correclty, because his drawing was corrupt. He did a Recover and then Wblocked the needed items and all was well.
Good luck,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
tcorey
in reply to: tcorey
Oops, you said Station/Offset labels. Disregard the first paragraph above.
Tim Corey
Redding, CA
Just figured out a file we disassociated with the file so the text is gone.  We found a .sv$ file from Frida so we did not have to do much updates.
Rail Community
