I have an xref...I can see the labels in model space but when I go to paperspace, I can not longer see them.
Solved by rkmcswain. Go to Solution.
Civil 3D labels?
Layer of the label object frozen in the viewport?
Layer of the label entities frozen in the viewport?
Yes Civil 3D. No the layers are not frozen. In the original C3D file...which is not my file...the labels come up as MTEXT.
@SkipBurns wrote:
Check that your annotation scale of the viewport matches exactly to the annotation scale of the text objects.
Civil 3D labels do not have an annotation scale.
@SkipBurns wrote:Right.... he said they are MTEXT.
@dgc74 wrote:
Yes Civil 3D.
Oops. I thought the reply above was to my question "Civil 3D labels?" I see the word mtext now, and your suggestion is spot on. Another quick way to check would be to set ANNOALLVISIBLE to 1.
Yes that annoallvisible command worked. What was the problem exactly? The annotative scale for MTEXT is not the same as a regular label?
Civil 3D labels and annotative text are different and behave differently.
Civil 3D labels will always display no matter what scale the VP is.
Annotative objects will only display if the scale of the VP is assigned to the annotative object (unless of course ANNOALLVISIBLE = 1). If you have multiple viewports with different scales, then you probably would not want ANNOALLVISIBLE set to 1.
If desired in your case, it sounds like you could assign the correct scale to your annotative objects, then set ANNOALLVISIBLE back to 0.
@rkmcswain wrote:
@dgc74 wrote:Yes that annoallvisible command worked. What was the problem exactly? The annotative scale for MTEXT is not the same as a regular label?
This is 100% correct. I would just add that ANNOALLVISIBLE will sometimes turn itself off randomly in paperspace so just be careful. Also, when assigning the correct scale to the annotative objects, be aware that they have to be exactly the same between the object and viewport (ex. 1:20 and 1:20, not 1:20 and 1"=20')
@SkipBurns wrote:
...... when assigning the correct scale to the annotative objects, be aware that they have to be exactly the same between the object and viewport (ex. 1:20 and 1:20, not 1:20 and 1"=20')
Good point. To further clarify that, this is because annotative scales are unique/defined by their name, not their scale ratio.
