Civil 3D Forum
Label cut depth
1 REPLY 1
178 Views, 1 Reply
Label cut depth
I am trying to create a label style that will include elevation of two surfaces, as well as the difference between the two at a given point in the model, which in this case is the cut depth. I haven't used the label styles much. Where do I find the text strings used to create various info in labels?
1 REPLY 1
MSchille-1994
You can create a volume surface and label spot elevations on a grid.  That will give you +/- depths.
Attitude, not Aptitude, Determines Altitude
Rail Community
