We have created sections from our corridor. We see FG and EG, we can use bands for EG from surface. How do we get the FG band to show the elevations for FG? The only option we have is the EG surface. We have tried to create a surface form the corridor in the corridor properties but that surface still doesnt show up in the surface list in the bands. I should think this should be fairly easy but am missing something here I think. I would hav ethought this info would be dynamic and come directly from the corridor would it not?
Most likely it is because you have not specified Section2 on the Bands tab of your Section View Properties.
If you scroll to the right, you will find columns for Section1 and Section2. Is this info filled in correctly?
Use Section View Group properties to set the band info for all sections. This will save you having to set one-at-a-time.
Tim
I am automatically creating a FG surface from my Cooridor model and it is listed under the "Section Sources" dialog box, it has a style, on a layer, and the update mode is "dynamic". Under the Sections tab of the "Section View Properties" dialog box, it shows the Corridor Data Source correctly; however, under the "Bands" tab, I can't select it under the "Section 1" or "Section 2" list. Those lists only show the surfaces NOT created from the coridor. What am I missing?
