AutoCAD Civil 3D General
Neilw
Message 1 of 7 (445 Views)
Label all parcel lines at once
445 Views, 6 Replies
04-27-2012 10:26 PM
I need to make a map of a subdivision with all lot dimensions. I see how we can label all the lines of a lot by picking the parcel label, but it only allows one at a time. Can we do them all at once?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
BrianHailey
Message 2 of 7 (424 Views)
Re: Label all parcel lines at once
04-29-2012 10:23 AM in reply to: Neilw
Not out of the box that I'm aware of. Perhaps one of the add-on programs like SincPac, Steltman, or Dotson would have something that would accomplish this. To justify the purchase of the add on, estimate how long it would take you to label all the lots without the tool, take your billing rate and see if the program is cheaper.
Neilw
Message 3 of 7 (413 Views)
04-29-2012 05:10 PM in reply to: BrianHailey
250+ parcels will take a while if picking one at a time. Then there is the time to flip all the labels that end up on the wrong side of a line. I've also considered exploding the parcels, cleaning up the mess and using featureline labels, but the FL labeler can only label one line at a time, so that's out. This is a case where I might resort to Land Desktop's labeling tools.
Yes we could find a custom solution but I wanted to establish that it can't be done with the available tools.
WIN 7 64 PRO
RADEON 6450, 1 GB
Jeff_M
Message 4 of 7 (411 Views)
04-29-2012 05:44 PM in reply to: Neilw
According to 2013's help (possibly earlier versions, too) you can:
To label multiple parcel segments
  1. Click Annotate tab,Labels & Tables panel,Add Labels menu,Parcel,Multiple Segments .
  2. Select the feature lines or segments to label.
    When parcel face is selected, a direction prompt displays. If a different supported object is selected, the direction prompt does not display.
    However, the actual command only allows selecting a parcel area label. Is this a bug? Or is the help that messed up?
Neilw
Message 5 of 7 (409 Views)
04-29-2012 06:09 PM in reply to: Jeff_M
I interpret the multiple segment option as being the same as the multi-segment featureline option in that a single featureline can have multiple segments. It does not allow the selection of multiple featurelines.
I haven't worked with parcels enough to know if there can be parcel lines with multiple segments.
WIN 7 64 PRO
RADEON 6450, 1 GB
Message 6 of 7 (394 Views)
04-30-2012 07:53 AM in reply to: Neilw
I find that subdivisions are best-labeled by placing labels one at a time.  That's because it usually takes a number of different label Styles to get it labeled properly.
We really need some sort of Rule Set for creating a "Parcel Label Set".  Maybe in a future version of C3D, once Autodesk finally gets back to improving Parcels (something that hasn't been on the radar in recent years).
Sinc
Neilw
Message 7 of 7 (389 Views)
04-30-2012 08:08 AM in reply to: Sinc
I was thinking about how there could be better intelligence to parcel labeling as well, such as recognizing Inside vs. Outside of a closed area.
I find that batch labels will be adequate for the majority of lots/parcels but there are always some that need tweaking. It would be helpful to have support for selection set labeling. Perhaps as you suggest if there were a way to have a label set applied when parcels are created I could just import the entire set of parcels into a new file and have a good start.
WIN 7 64 PRO
RADEON 6450, 1 GB
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
