Is it possible to label a pipe crossing offset in section view dynamically? I see there are options to label start offset and end offset, but not at the actual crossing. Am i missing something?
Jason,
Thanks for your response. When I label my pipe crossing in section view the style gives me options to call out the beginning and ending offset and elevation, however the section is not cut at the beginning or end it is somewhere between. For example my pipe begins at 1+00 and ends at 2+00, but my section is cut at 1+50. I only see options to label at 1+00 or 2+00 it does not appears i can get elevation and offset at 1+50.
I use a Section View Offset Elevation label with a reference text component to bring in the pipe size material and slope. I have the section view label get me the invert. Though I get the invert I want these labels are not dynamic to the pipe.
John Mayo
Cosmo12,
Thank you for clarifying, I apologize that I misunderstood your question. At this time the out of the box label for Crossing Section pipes will not allow you to do this.
However as John mentioned there are other options to label the information you want, though I know you would prefer this be dynamic.
Thanks guys. I went and manually added them. I wonder if this function will be added in the future.
