I want to hide/delete/no display the small line that intersects my contour line labels, but I don't know what it's called? Can someone help out?
Thanks.
Solved by Lisa_Pohlmeyer. Go to Solution.
Solved by sboon. Go to Solution.
Solved by Jay_B. Go to Solution.
"Contour Label Line" set to False in Properties Palette.
This Can also be set to False in the Feature Settings Tab> Surface>Rt. Click>Edit Feature Settings>Contour Labeling Defaults>Display Contour Line>False in the dwt.
Make sure that your Properties palette is open then select one label, right-click to Select Similar
