Civil 3D Forum
Label Objects on individual layers
30 REPLIES 30
Message 1 of 31
civman_daar
796 Views, 30 Replies
C3D 2012 Win 7 Pro
I have Note label Style objects and Marker Style Objects that have layers assigned to them.  When I bring a Note label or Marker Style into the drawing, it comes in on the zero layer.  I know that the object layers of the drawing settings are controlling this.  Is it possible to have the Note labels and/or Markers come in on the assigned layers of their Styles?  What settings(s) achieve this?
30 REPLIES 30
Message 2 of 31
Edit Drawing Settings>Object Layers tab...
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
Message 3 of 31
civman_daar
in reply to: civman_daar
I see that the Object layers for General Note Label and General Segment Label are set to C-ANNO
If I have a Note Style Object that is assigned a Layer of V-ANNO-UTIL-TEXT and assuming I set the General Note Label and General Segment Label to V-ANNO, per your example, will the labels come in on V-ANNO or the object assigned layer of  V-ANNO-UTIL-TEXT?
Message 4 of 31
V-ANNO.
Todd Rogers
BIM Manager
Message 5 of 31
I need the notes to come in on V-ANNO-UTIL-TEXT, V-ANNO-SITE-TEXT, etc.? I have probably 60 Note Style objects that go to different layers. Any Ideas?
Message 6 of 31
Change the layer to the layer you want them to go on in the drawing settings like I posted in the pic.  If you change the layer to V-ANNO-UTIL-TEXT, it will come in on that layer.
Todd Rogers
BIM Manager
Message 7 of 31
civman_daar
Do you mean to say that I have to change the object layers every time for each individual layer?  Is there no way to ONLY use the layers assigned to the Note Style Objects, bypassing the object layers themselves?
Message 8 of 31
troma
Not that I know of.
I posted that on the wish list, RIP.
Mark Green
Working on Civil 3D in Canada
Message 9 of 31
DaveM
in reply to: troma
Sinc pac has a function that will have your lables automaticaly come in on the current layer.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
Message 10 of 31
AllenJessup
You can set your destination current, create the labels that you want on that layer, select them using Select Similar or Quick Select and then use Laycur to bring them on to the current layer.
Allen Jessup
Allen Jessup
Engineering Specialist / CAD Manager
Message 11 of 31
troma
in reply to: DaveM
Nice, but not what I want.
I want labels to come in on the layer specified in the label style.  I think the OP's request is similar.
Mark Green
Message 12 of 31
Jeff_M
in reply to: troma
I've just added this capability to Sincpac. It will be available in the next release, due out soon.
Message 13 of 31
AllenJessup
in reply to: Jeff_M
I'm looking forward to that.
Allen
Allen Jessup
Message 14 of 31
troma
in reply to: Jeff_M
Very nice.
What version of the software is this going to be in?
Mark Green
Message 15 of 31
Jeff_M
in reply to: troma
It will be in all currently supported versions (2010+). It is currently limited to the Note Labels only.
Message 16 of 31
civman_daar
in reply to: troma
What about a routine for the marker styles as well?  The note label style and marker style would then be segregated onto individual layers.
Message 17 of 31
Jeff_M
Yes, I re-read your initial post this morning and saw that you had mentioned the markers. I will add those to the code. Now, these are only the markers associated with a Note Label, correct?
Message 18 of 31
civman_daar
in reply to: troma
Yes, the markers associated with the Notes.
Message 19 of 31
Jeff_M
OK, after researching this, I don't see a normal method to do this. The Marker is actually a part of the NoteLabel and is not designed to be added to the drawing unconnected from a parent object.
Message 20 of 31
wetsnow13
The object layer in drawing settings is the base layer for all your notes (call it ob-note), Object > General Note Label. When you create your Note Label Style you can specify the layer (la-note-1) on the General tab. If you create a second Note Label Style you can change the layer (la-note-2) on the General tab. Turning off just la-note-1 turns off the first note and leaves the second note on. Turning off ob-note turns all of them off regardless of on/off freeze/thaw on the sub-layer. Same with the marker style - which can be a different layer and controled individually as well. One note can be controled by ob-text (for all), la-note-1 (for just the note on that style) and mk-note-1 (for just the marker on that style). Basically you need to create as many styles as you'd require layers - PITA. For C3D2012: Arrowheads (in B&D line labels) and leaders for drag state use the plot style for the object layer - so be mindful of not leaving it on 0 if you have 0/white set super thick.
Rail Community
