Civil 3D Forum
LINK CODE
8 REPLIES 8
Message 1 of 9
CLAUDIO_GUSMAO
501 Views, 8 Replies
LINK CODE
HOW TO ADD, TO EXCLUDE OR TO EDIT THE CODES OF THE SUBASSEMBLIES BASICSIDESLOPECUTDITCH AND DAYLIGHTBENCH ?
C3D 2008 SP2
INTEL CORE 2 DUO 6550 / 2.33 GHz
4 GB RAM
THANKS
CLAUDIO GUSMÃO
CIVIL ENGINEER
8 REPLIES 8
Message 2 of 9
Claudio,
Type CODES in Civil3D help and read Understanding Codes topic. You'll find everuthing you're looking for. There is a step by step to change it.
M.Porretto
C3D 2008 SP2
Message 3 of 9
IT SEEMS NOT TO BE POSSIBLE WITHOUT VBA.
CAN BE MODIFIED THE PARAMETER LINK CODE OF ANY SUBASSEMBLY GENERIC LINK, BUT NOT IN SUBASSEMBLIES BASICSIDESLOPECUTDITCH AND DAYLIGHTBENCH.
IT SEES THE FIGURE ATTACHED.
Message 4 of 9
in reply to: CLAUDIO_GUSMAO
You can't change the codes on .Net subassemblies without coding.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5898264@discussion.autodesk.com...
C3D 2008 SP2
4 GB RAM
THANKS
CLAUDIO GUSMÃO
CIVIL ENGINEER
Message 5 of 9
Claudio,
While you can't add or remove codes from the stock subassemblies without
modification of the VB.NET code, you can change text that is used inside of
Civil 3D by editing the C3DStockSubassemblyScripts.codes file. This file has
the following information for each of the codes used by the subassemblies:
1. Index Number
2. Localized Code
3. Original code
4. Description
For example the line:
6,ETW,ETW,Edge of traveled way; inside or outside edges of travel lanes on
finish grade
could be changed to:
6,EOP,ETW,Edge of pavement; inside or outside edges of pavement on finish
grade
After this change is made, you will see EOP used inside of Civil 3D instead
of ETW.
The C3DStockSubassemblyScripts.codes one of the files that is modified as
part of the Country Kit process that we use to localize Civil 3D for 22
different languages and countries.
Cheers,
Peter Funk
Autodesk, Inc.
Message 6 of 9
Why thank-you Peter.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
; "Inc." wrote in message
news:5898628@discussion.autodesk.com...
Claudio,
1. Index Number
2. Localized Code
3. Original code
4. Description
finish grade
grade
of ETW.
Cheers,
Peter Funk
Autodesk, Inc.
Message 7 of 9
Have you considered adding the point code through a range (or all) within
the Cross Section Editor? Or placing a MarkPoint on your sub (not sure
exactly how this works... read it on this DG)?
Happy Modeling,
JD
Message 8 of 9
IN THE TRUTH I DO NOT INTEND TO USE CROSS SECTION EDITOR.
I NEED TO CREATE A ASSEMBLY THAT CONTAINS TWO SUBASSEMBLIES BASICSIDESLOPECUTDITCH WITH DIFFERENT CONFIGURATIONS.
CONFIGURATION 1 - WITHOUT LINK CODE DATUM
CONFIGURATION 2 - WITHOUT LINK CODE TOP
I THINK THAT THE CIVIL 3D STILL IS LIMITED IN RELATION TO FLEXIBILITY IN THE CONSTRUCTION OF PROJECT SECTIONS. I AM TRYING TO MAKE AN ADAPTATION.
IN THE LAND IT IS POSSIBLE TO CREATE A SUBASSEMBLY AND TO PROGRAM TO BE USED ONLY IN CUT SECTIONS, BUT IT SEEMS THAT IS NOT IN THE CIVIL 3D.
Message 9 of 9
THANK YOU FOR YOUR INPUT CLAUDIO. I'LL ADD AN ITEM TO OUR WISH LIST TO ALLOW
FOR THIS FLEXIBILITY IN THE FUTURE.
PETER FUNK
AUTODESK, INC.
Rail Community
