Civil 3D Forum
LINE CODES
2 REPLIES 2
danthron
327 Views, 2 Replies
LINE CODES
Our Survey Dept. Uses Illinois DOT codes.
An example would be for edge of gravel ( .665 GRVL )
Im having problems getting the line work to automatically process.
If I change the Name in the Figure Prefix Database from ( .665 GRVL to GRVL )
It will create some line work but not in the correct order.
Is it not possible to use survey codes beginning with numbers in Civil 3D?
Any changes I make in the Linework Code Set Database seem to have no affect.
Any suggestions would be greatly appreciated.
2 REPLIES 2
AllenJessup
in reply to: danthron
If you don't get anywhere you could try PConnect. I've seen it run with numeric codes.
Allen
Allen Jessup
CAD Manager - Designer
mikeharris17
We also use numeric codes. I can tell you with certainty that it will work, but I'm not sure why it won't work for you. Don't give up.
Rail Community
