I have a user with Civil3D and he has an odd problem. He has several text objects on several layers that all are assigned the "L100" text style. We use a CTB still and when he prints leaders and other objects on the same layer and same color are normal, but the text itself (mtext) is much thinner.
I checked the mtext to make sure it was set to "by layer" and everythign seems fine. I then changed the text to "L" style and they immediatly got darker on the screen and now print just fine. When I look at "style" L100 and "L" appear to be indentical.
Any idea what the issue is here?
Solved by Joe-Bouza. Go to Solution.
Does the style have a font overide?
Your Name
Post a drawing...
Here is the drawing, I removed everything but one of the mtext entities and a leader. They are ont he same layer and set to color by layer, but if you change the text to L100 you will see it thins.
Thanks for takign a look!
L uses simplex.shx and L100 is calling a trutype simplex
Your Name
