Solved by richie_hodgson. Go to Solution.
HI Richie,
Can you post a sketch of what you would like to achieve?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Thanks for replying I worked it out myself in the end. I created a dummy cut fill slope at 1:5 from the back of kerb. This gave me an indication of where the alignment around the existing central roundabout would go. Then I used a Feature Lines From Corridor to create a feature line of the back of kerb. So I was able then to creat a new corridor to do what I wanted, see attached for before and after shots. Pardon the tangency errors.....
