Civil 3D Forum
Keeping surfaces separate?
3 REPLIES 3
deltacoolguy
592 Views, 3 Replies
I did a quick work-around to get this one done, but am asking for future reference.
I have a finished surface that I am satisfied with, and do not want to change.  I wanted to create a separate surface that abuts the finished surface, but is at a different elevation.  When I create feature lines for the new surface, the existing finished surface gets the warning symbol telling me it has changed, even when I select objects instead of existing feature lines and type in different elevations.  This alarmed me, so I quit the process and closed the draswing.
How can I create surfaces in the same drawing that are completely separate?  Or, how can I create feature lines that don't attached to adjoining feature lines?  (In the vast majority of situations I like that a new feature line will take on the elevation of a picked feature line)
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
3 REPLIES 3
AllenJessup
in reply to: deltacoolguy
Create the Featurelines in a different Site. That way they shouldn't interact,
Allen
Allen Jessup
CAD Manager - Designer
csevers
I will just offset the feature line a very small amount, like .01 ft., then infill the gap.
Or what Allen said if I misunderstood what you are trying to do.
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
deltacoolguy
in reply to: AllenJessup
Allen
I did create a different new surface first, but did not create a new site.  That makes sense.  I figured there must be a relatively easy solution.  Thanks.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
Rail Community
