1) Re: Pressure pipe networks. Why can I not change the appearance of appurtenances in profile view? I would like to mask them in both plan and profile and show the pipes end to end.
Also for some reason I can only create a pressure pipe network from the prospector, no pressure pipe options are listed under pipe network on the ribbon. Anyone have any feedback?
2) If I adjust my viewport scale via the properties panel as I scroll over the list it regens the viewport as I highlight each option. This slows me down quite a bit. This did not happen in 2012, I assume it is a setting somewhere?
Solved by david.zavislan. Go to Solution.
Solved by Jay_B. Go to Solution.
Should be right here in 2014.
Was anything migrated over from 2012?
The reason I ask is because I can see a Flyout on your Corridor Tab.
2014 Only has one Corridor type. 2012 had 2.
We need the full migration story in order to help. My suspicion is you've managed to use the 2012 Ribbon in 2014.
I suspect you are both correct. I simply ran the installer provided by IT. I did not intentionally migrate anything from 2012. I have both 2012 and 2014 currently installed on my machine. How would I have ended up with the 2012 ribbon and how would I go about getting the 2014?
Also thanks to you all for the quick replies.
Resetting the User settings will restore everyting to a default state.
Any customization will be lost.
OK everything is working fine now with the pressure networks. I had imported a couple of shortcuts from 2012 and apparently whatever I did was not the way to do it. I stil find that CUI confusing. Thanks for the assistance. Anyone know what I am talking about with the viewport scale?
Try setting PROPERTYPREVIEW to off. This controls the previewing of changes to selected objects when rolling over drop-down list.
