Have you applied a surface style that will show something, such as contours?
The default surface style shows only the border (edges) of the surface.
wrote in message news:4963532@discussion.autodesk.com...
Ok, so forgive me if this is a simple task, I'm new to MAP and autoCAD too.
I just imported a dgn file. I want to create a TIN surface using the
elevations stored in this map. I can get as far as creating the empty TIN
but I seem to be having problems adding anything to it. I have read all the
help and I seem to be doing things correctly, but nothing is working and the
TIN stays invisible, even though it says it has breaklines etc. ANY help or
ideas would be appreciated.
Margaret
