Hi
I have two different assemblies, one has a normal batter slope to a table drain or embankment and the other is a kerb and channel. Refer attached.
When you apply these two assemblies in ajoining regions, I get both assemblies at the same point, which causes the corridor surfaces to incorrectly triangulate.
Is there a way to stop this from happening.
Thanks.
Jason
You'll need to create a gap between the 2 assemblies. The corridor will show the gap but the surface model will triangulate between the ends of the strings.
If you can't live with a gap in the corridor you'll have draw lines to connect the strings across the gap and use them as targets for the subassemblies.
Corridors do not support automatic transitions.
A search on the topic "transitions" will provide a wealth of info on this question.
