AutoCAD Civil 3D General Discussion
New Member
stirgras
Message 1 of 3 (422 Views)
Accepted Solution
Issues with section view label text size in paper space
422 Views, 2 Replies
09-11-2013 06:34 PM
When I use a layout size such as A3 in paper space, the section view label text size is the same as it is in model space (when both annotative scales are the same). However, when I choose 11x17 as a layout size, the section view label text size is exetremely small. I can't seem to solve this issue and I'm wondering if anybody has experienced a similar problem.
*Expert Elite*
sboon
Message 2 of 3 (413 Views)
Re: Issues with section view label text size in paper space
09-11-2013 09:08 PM in reply to: stirgras
Start the plot command and check the settings in the dialog.  When you use a metric template but your layout has an Imperial sized sheet the software sets the scale to 1" = 25.4 units.  Civil 3d adusts the size of labels and other objects to suit this 1 : 25.4 scale factor but unfortunately doesn't recognize that there are different units involved.
Change the scale back to metric 1 : 1 then Apply the new settings and exit without plotting.  You might have to regen.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
New Member
stirgras
Message 3 of 3 (396 Views)
09-12-2013 11:02 AM in reply to: sboon
That did it! Thanks a bunch!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
