AutoCAD Civil 3D General
Distinguished Contributor
dwk1204
Message 1 of 4 (292 Views)
Issues with Cogo Points in Paper Space
292 Views, 3 Replies
01-21-2014 07:48 AM
I have a drawing that contains all my cogo points xref'd into my main drawing. Model Space and Paper Space are both set to 1:100. The points look great in model space, but are about 5 times larger in paper space? I was wondering if it had something to do with it being an xref, but when I open the actual xref I get the same behavior?
Any help would be greatly appreciated and thanks in advance..
Civil 3D 2014
Jay_B
Message 2 of 4 (279 Views)
Re: Issues with Cogo Points in Paper Space
01-21-2014 08:43 AM in reply to: dwk1204
Verify the plot scale units in the Page Setup definition are set properly to inches or mm.
Jay
C3D 2014 SP1
Win 7 Professional 64 Bit
Distinguished Mentor
andrewpuller3811
Message 3 of 4 (236 Views)
01-22-2014 06:37 PM in reply to: dwk1204
Sounds like your Point Style setings.
Look into the Marker Size options for Point Styles.
You can set the marker (symbol) to -
  • Use Drawing Scale
  • Use Fixed Scale
  • Use Size in Absolute Units
  • Use Size Relative to Screen
I would gues your point styles are set to Use Drawing Scale or Use Size Relative to Screen.
Try this page -
http://docs.autodesk.com/CIV3D/2014/ENU/filesCUG/GUID-B0406250-A4F2-48CB-BEC2-781B0799FDE7.htm
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
SurveyorLee
Message 4 of 4 (202 Views)
01-25-2014 08:20 PM in reply to: andrewpuller3811
check yoru annotation scale settings too.  I had that issue with one of my drawings.
Surveyor Lee
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
