I'd like to observe my aligment (even my corridor) at plan view.
I could use the section editor and tracking or inquiry tools,
But I'd like to activate some tool to view a rubber band linked to my aligment and a box (or something like this) with station , offset, and other useful information...
In adittion, Inquiry tools only uses one point each time ? does it exist some "continuous" mode??
Any idea if exist something like I want ? Thanks
Civil 3D (2013) how much you have to improve....
Try the station tracker on the Analyze tab of the ribbon.
In my case station tracker does nothing .....
No...
I'd like a rubber band ... like that you see when using frecuency "specify aditional stations".
My idea is having a tool to evaluate tjhe station of any point or element in "visual style".
The tooltip is a slow an unconfortable tool.... many time to view the information.... In addition you must have inside the influence area of the corridor you want information from.
I simply want a rubber band "live" information tool.
I think there is not an option.
Thanks.
I know this is not what you are looking for but go back to the first responder and use the Station Tracker. Split your screen and zoom one side of the monitor to the profile and the other side to the corridor. Set STracker to All Viewports and you can get some info that may be helpful.
Bill
