AutoCAD Civil 3D General Discussion
tonnot
Message 1 of 3 (70 Views)
Is there any way to get ONLY radius or spiral value on geometry points labeling?
70 Views, 2 Replies
09-12-2013 10:55 AM
I know I can use "<[Geometry Point Entity Before Data(CP)]>" (or after...) .
But this text is tooooooooo long.
Is there any way to get only  the :
- radius - length of segment. or  - Spiral A ???
Any hidden trick ? Maybe using expressions? In this case any hidden elements? ANY TRICK ?????
I know I can use segments or multiple segments but I want to do the work in only 1 labeling step ...
Thanks.....
Civil 3D (2013) how much you have to improve....
Employee
peterfunkautodesk
Message 2 of 3 (66 Views)
Re: Is there any way to get ONLY radius or spiral value on geometry points label
09-12-2013 11:05 AM in reply to: tonnot
Not with 1 labeling step. You'll have to use 2.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
tonnot
Message 3 of 3 (62 Views)
09-12-2013 11:14 AM in reply to: peterfunkautodesk
So then .... please think on users.......
Program this please :
"Geometry Point Entity Radius or Spiral A  Before Data"
"Geometry Point Entity Lenght  Before Data "
(I dont understand the reason to join all the information on "Geometry Point Entity  Before-After Data". Is that you have never seen the big clutter you have if use it ?) ..... Oh my god....
Thanks any way.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
