Civil 3D Forum
Is there a way to break survey figures in two?
4 REPLIES 4
ltmullen
2697 Views, 4 Replies
Is there? I tried executing the BREAK command on a survey figure and it doesn't work.
4 REPLIES 4
ltmullen
in reply to: ltmullen
OK, figured it out. Apparently I needed to use the BREAKFEATURES command instead of the BREAK command. Kudos to me 🙂
AllenJessup
Kudos for posting the answer and marking it as the solution.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Thanks for this. Do you know if there is a way to automate this upon importing survey data?
That's easy just starting the same figure name will do that, yet there are many ways to accomplish it. I'd sincerely recommend starting a new thread vs continuing an old one you'll get better results.
Rick Jackson
Survey CAD Technician VI
Rail Community
