AutoCAD Civil 3D General
Member
Message 1 of 8 (240 Views)
Invert Contours (Positive Elv to - Elv)
240 Views, 7 Replies
04-10-2012 11:48 AM
I have a contour map that i need to flip all the postive contours to negitive. So the Z cordinate for example is Elv 40 now i need to invert it to -40. I want to do this to the whole large contour map. ????
Shawn
Alfred.NESWADBA
Message 2 of 8 (238 Views)
Re: Invert Contours (Positive Elv to - Elv)
04-10-2012 11:50 AM in reply to: sdrobs
set the UCS to look from the right side (or from front) and then mirror your contours.
- alfred -
Alfred NESWADBA
Distinguished Mentor
thepworth
Message 3 of 8 (224 Views)
04-10-2012 12:59 PM in reply to: sdrobs
is it contour data or contours representing a TIN/DEM?
If its contours as CAD objects, you could use the Map3D side of C3D to perform a drawing query to multiply all contours by a (-1) value and then recreate the surface.
I'm not a fan of surfaces from contours w/o the breaklines.  The software has gotten better, but there's still a loss.
The miserable brute-force way would be to export to xml and then replace the elevations with a "-" character.  dunno even where to approach that
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Member
Message 4 of 8 (205 Views)
04-10-2012 03:30 PM in reply to: sdrobs
Thank you, i will give that a try.
BrianHailey
Message 5 of 8 (196 Views)
04-10-2012 04:11 PM in reply to: sdrobs
Create a surface from the contours (do all the minimizing flat area options, you can read why HERE) if it's not already a surface. Create a flat surface at elevation 0 that's totally encompasses your surface. Create a volume surface that compares your surface as the base surface and the 0 surface as the comparison surface. Have the volume surface display contours. Extract the contours from the surface (if you don't want to have the surface).
Member
Message 6 of 8 (195 Views)
04-10-2012 04:14 PM in reply to: sdrobs
Thank you so much, that worked.
Shawn
thepworth
Message 7 of 8 (184 Views)
04-10-2012 08:49 PM in reply to: BrianHailey
Guess I was having a "blonde moment" when I didn't think of that one ealier - nice!
C3D 2011
BrianHailey
Message 8 of 8 (172 Views)
04-11-2012 07:27 AM in reply to: thepworth
It's a technique I used to use in LDT to help delineate watershed boundaries, create an inverted surface and use the water drop tool on it.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
