Civil 3D Forum
Intersection curb return fillet
3 REPLIES 3
mrthra
2950 Views, 3 Replies
Hi all,
I have an issue with the above which i am having real trouble solving. Please see the screenshot below which is fairly self explanatory.
You will note that the curb return fillets are forming on the inside of the radius rather than the outside. The daylight is then shooting off back across the radius! It doesnt matter which subassembly i use, it always ends up like this!
Is there something simple that i am missing in the setup which is causing this?
Many thanks for your wisdom in advance!
regards
Using AutoCAD 2014 & Civil 3D 2015
AutoCAD 2013 Certified Professional
3 REPLIES 3
kcobabe
in reply to: mrthra
More than likely you will have to flip your assembly or reverse your alignment.
You can also ad more than one target, which need to be done on intersections with a crown on both roads.  I typically no longer use a profile for intersection targeting as it's much easier and a more on the fly kind of thing to use a feature line.  Of course most people still use alingments and profiles.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
mrthra
in reply to: kcobabe
Very simple in the end, I just mirrored the assembly of the kerbline and its flipped it over on the plan!
Thank you!
kcobabe
in reply to: mrthra
No problem.  I know that drove me nuts on my first intersection corridor.  Glad I could help.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Rail Community
