I m trying to create an intersection between two roads. See the attached jpeg. When i open the corridor properties i receive an error message which i don't understand. It seems like civil 3d has problem with the order of the regions. Also the corridor sections intersects in the area that i have place a remark "problem". I m trying to correct it manual but when i rebuilt intersection then it overlaps my manual correction
Also i have another question for intersections. In this drawing i have the design profile as shortcut. I have made manual in the original drawing the design profiles of the intersection roads to have the same elevation in the intersection point. But with this way the intersection tool cannot modify them. I have done with this way because i don't understand the way with civil 3d modify profiles . And it looks fine between 2 flat roads but in my way in witch the first intersection road has slope 17% and the other 12% the result inst correct
Ī¹ omitted something . These regions was created automatically by the intersection tool. If you see the attached picture the program creates two times the existing road full section region (38 & 5). The second region begin and ends in the same region (5). So in the first picture i had remove the second region. Now when i try to remove the first (38) region and correct the start station of the second (5) the problem seems to solve . I also manually solved the crossing section problem which i describe in the first post. But if i run the command " update regions and rebuild corridor " then it came back to first condition. I think that the crossing section responsible for the problem and that happens because the secondary alignment is almost tangent to the arc of primary alignment. The issue is how to resolve it?
