I cant seem to change the display or size of the intersection marker. is this a known issue?
Your Name
Your Name
Solved by Jeff_M. Go to Solution.
Thanks Jeff
I must be editing in the wrong place. This is what I changed.Is there a different setting to adjust?
Your Name
Your Name
Close but wrong tab.....
Don Ireland
Engineering Design Technician
Hmmm. I wasn't able to change the size on the display tab -- but I could turn it on/off, change color etc.
Don Ireland
I think I am? I tried the light bulb, size, a blank marker, I'm flummoxed.
Your Name
Your Name
Point you have highlighted (which I'm assuming you're using) is BLANK which doesn't show at all. Have you tried selecting the X or +? And using either of those, have you changed the size in the uppper right corner?
Don Ireland
Interesting: it doesn't react to changes in the prospector settings tab, but if I grip and RC the marker it reacts to the lightbulb getting turned off. Thats wierd. Well now I am really puzzled! I go back to the marker style in the prospector an the light is on but they are off in the drawing. Where is the marker definition stored?
Your Name
Your Name
Your Name
Your Name
What-a-Maroon!
Let that be a lesson to you Bouza: back up and relax before you panic!
Thanks, Jeff
Your Name
Your Name
