I have created a label in Settings>Intersection>Label Styles>Intersection Location Labels. The label will annotate the intersection stations and alignment name - however I haven't been able to configure the northing, easting and point number of the intersection. Any clues on what I'm doing wrong?
Thanks for any suggestions.
April
After a bit of research, the way to do what you want is to add Reference Text to your Intersection Location Label that references a Cogo Point, since you want a Point Number in addition to a Northing Easting.
Now if you already had labeled your Intersection Location, you will see ??? marks as part of your label. If you do not already have a Cogo Point defined at the intersection, add one. Now select the existing intersection label, and then open up the Properties dialog box. In the dialog box, you will notice a Reference Text Objects section and reference to Cogo Point. Click on <none>, pick the Selection button on the right, and then pick your Cogo Point.
If you did not already have a label apparently you will prompted to select the reference object when you place the intersection label.
That should do it. Thanks for the question, I learned something new.
Alternately, if you did not need a point number, you could have added a Reference Text Component that references one of the alignments with a label for the Northing and Easting.
