I am a beginner with AutoCad software, and I am currently using Civil 3D 2009.
I imported a shp. file containing property information (owner, area, address, etc), and also imported a road row. as a sdf. file. The row. is a closed polygon
My goal is to intersect these two types of data so that I end up with information on the number of properties effected by the row. Is civil 3d capable of doing this? If so, how?
It can absolutely do that, but the features you're inquiring about are ones that come from the Map vertical. Civil3D includes the Map funcitionality, however, the best place to get Map releated advice is on the Map forum. So I'd go post there if I were you.
Best of luck!
