Civil 3D Forum
Intersect two gradings
14 REPLIES 14
Message 1 of 15
Neilw_05
816 Views, 14 Replies
I'm a bit perpplexed about a very simple grading scenario: intersect the daylighting of two gradings as shown in the screen capture. I would like a solution that is dynamic to changes in either of the 2 gradings.
The intended result is in the 3D PDF.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
14 REPLIES 14
Message 2 of 15
Joe-Bouza
in reply to: Neilw_05
Hi Neil
I dont understand the overlap of the two. Could you giv a bit more detail?
Joe Bouza
Message 3 of 15
graf_p
I'm thinking while I'm typing here, so hopefully this makes sense.
Create 2 compostites surfaces:
1. Create surface named EX_ROAD and paste in the Existing surface and then the Road surface.
2. Create surface named EX_DITCH and paste in the Existing surface and then the Ditch surface.
Then Daylight the Road (grading object or corridor)  to EX_DITCH surface & Daylight the Ditch (grading object or corridor)  to EX_ROAD
One last thing, Make you composite surfaces a "no display" surface too.
Message 4 of 15
Neilw_05
in reply to: graf_p
The problem I have is if I create the intermediate surfaces to use as targets, I can't get them to clean up to form the intersection as shown in the PDF. I can get the road to match the ditch or the ditch to match the road but not both. Ultimately both the ditch and the road need to be pasted into a final finished surface.
The only solution I can come up with is to explode the gradings and manually trim out the featurelines to get the desired result. On a project where this type of intersection occurs frequently that is not a practical solution.
If someone can put together a simple example to show how it works it might help.
WIN 10 64 PRO
Message 5 of 15
graf_p
Iam sorry. I guess I don't get it then. Getting multple grading objects to interact is a constant struggle for me.. Now this it's not a solution, but I always end up extracting my proposed grading contours to it own drawing & then clean up the polylines using the mapclean function and makes tweaks such as filleting the polyline contours to make the look pretty. Any contours that Civil 3D creates, beyond a simple corridor or grading object pad, never passes our quality control for how a grading plan should look. Too many jagged lines & weird breaks.
Message 6 of 15
Neilw_05
in reply to: graf_p
Perhaps it's not clear from the explanation. In order for the gradings to have a solution the ditch and the road have to overlap. Therein lies the problem. I don't know how to clean up the overlap using the intermediate surface approach.
WIN 10 64 PRO
Message 7 of 15
Neilw_05
Well I'm feeling a bit foolish. The solution is simple. Using an intermediate surface that includes the EG and the ditch as a target for the road, I establish the match between the road and ditch. Then in the FG surface I first paste the ditch,  then the road. The road wipes out the ditch overlap leaving a perfect seam. No need for the 2nd intermediate surface.
Sorry for the confusion.
WIN 10 64 PRO
Message 8 of 15
owenmull
If the issue is simply getting two gradings to interact. Civil 3D will not interact gradings unless they are of the same Site. This works much in the same fashion that feature lines work, in that feature lines within a common Site will interact with each other, while feature lines in seperate Sites will not interact.
In order to create a link in the gradings between your ditch and road, create both in the same Site, and Civil 3D will automatically merge the two.
HTH.
-owenmull
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
Message 9 of 15
graf_p
Good job.  Smiley Happy That does make sense. No need to feel foolish.
Message 10 of 15
Neilw_05
in reply to: graf_p
Interacting the gradings is not the answer for the reason I tried to explain. There is no simple way I can see to get the 2 gradings to cleanup precisely. I think it will require using intersectiing surfaces.
If you have a dataset can you run through the exercise and present the workflow? It shouldn't take much time. If you do, please use a skewed ditch relative to the roadway for a realistic scenario.
WIN 10 64 PRO
Message 11 of 15
Joe-Bouza
I started sketching your scenario and had a thought: Maybe the intersection wizard could help?
Joe Bouza
Message 12 of 15
Neilw_05
in reply to: Joe-Bouza
I definitely don't want to create alignments and profiles for somethng like this Joe. This is a very common grading scenario so K.I.S.S. applies.
The intermediate surface approach works ok but if it can be done with just gradings that would be best.
Thanks for looking at this.
WIN 10 64 PRO
Message 13 of 15
agendahispana
So the algorithm steps are as follows?
1. Surface-EG
2. Surface-Ditch
3. Surface Composite- EG_Ditch
4. Grading-Road withTarge Surface Composite-EG-Ditch
5. Surface Road
6. Surface Composite-EG_Ditch_Road
Message 14 of 15
Neilw_05
in reply to: agendahispana
You got it.
WIN 10 64 PRO
Message 15 of 15
A little tip to help keep things simple and in order.
When I create compostite surfaces I name them as below.
EG1
Corridor 1 - TOP
COMP1 - EG1 with Cord 1 TOp
Pond1  - (this uses COMP1 as its EG surface)
COMP2 - COMP1 with Pond1
Parkinglot 1 - (This uses COMP2 as it EG surface)
COMP3 - COMP2 with Parkinglot 1
ETC
I've seen projects with up to 9 composite surfaces all working in full harmony! Also a prime example of when to use data shortcuts, just make sure to toggle the rebuild Automatic for all above surfaces. Also make note that you can also do some simple edits to each of these comp surfaces if required to get them to look proper.  i.e.  swap edge
Bill Neuhauser P.E.
Rail Community
