I'm getting this same error when exporting a file to acad 2004.
I've run recovery and audits and purge on the xref, it still happens.
any suggestions?
If I detach the xref it exports fine... but I can't bind or insert the xref... things just dissappear
If I detach the xref then reinsert it and then try and export it, it gives an error that couldn't bind the xref, the pops up the scandr 40 error and exits
Message was edited by: clay stringer
