Civil 3D Forum
Internal Error when Printing
7 REPLIES 7
Message 1 of 8
jschuur
863 Views, 7 Replies
I get an message that says
INTERNAL ERROR: !scandr.cpp@815: ePermanentlyErased
does anyone have any ideas it would be a great help. I have been plotting for the last 3 days and it just appeared all of a sudden??
7 REPLIES 7
Message 2 of 8
in reply to: jschuur
having the same problem.
Message 3 of 8
this issue has just occured on one of our engineers machines. it also happens on my machine when i try to plot the file. so this issue is definately file related. i will update with any solutions i find.
note: it does plot to pdf just fine.
Matt
Adams and Clark
Message 4 of 8
see also: http://discussion.autodesk.com/thread.jspa?messageID=5781232
Message 5 of 8
Matt.Anderson
or
http://www.civil3d.com/2007/12/a-drawing-saver-or-drawing-savior
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 6 of 8
as that post mentions, our issue was resolved by recovering the xref drawings.
Matt
Adams and Clark
Message 7 of 8
Do you happen to know how this works with vaulted drawings?
Message 8 of 8
I'm getting this same error when exporting a file to acad 2004.
I've run recovery and audits and purge on the xref, it still happens.
any suggestions?
If I detach the xref it exports fine... but I can't bind or insert the xref... things just dissappear
If I detach the xref then reinsert it and then try and export it, it gives an error that couldn't bind the xref, the pops up the scandr 40 error and exits
Message was edited by: clay stringer Message was edited by: clay stringer
Rail Community
