AutoCAD Civil 3D General
Active Member
Message 1 of 7 (1,117 Views)
Install Infrastructure Design Suite Premium 2014
1117 Views, 6 Replies
06-25-2013 08:34 AM
The installation of IDSP has been an adventure. After a few rough starts Autodesk support team got us through the installation of 2 computers. Now I am attempting to install IDSP on my computer and have run into a number of errors that between this forum and Autodesk support I have worked through.
I start the install once again and looked like everything was installing ok.
That is until I get an message "Allied product is not found" and the install fails and removes all installations up to this point. The failure happened while installing the Civil 3D Language Pack.
Install log states:
2013/6/24:15:51:11 Administrator ______ Allied product is not found2013/6/24:15:51:35 Administrator ______ Install Autodesk AutoCAD® Civil 3D® 2014 Language Pack Failed Installation aborted, Result=1603
This install saga is endless!
*Expert Elite*
rkmcswain
Message 2 of 7 (1,111 Views)
Re: Install Infrastructure Design Suite Premium 2014
06-25-2013 08:40 AM in reply to: MEK_EST
Active Member
Message 3 of 7 (1,089 Views)
06-25-2013 11:02 AM in reply to: MEK_EST
The only thing I found addressing the statement "Allied Product is not Found" is in reguards to an uninstall nothing about during the install. The Result-1603 seems like a generic error for multiple issues.
Here is the statement from the install log I get.
2013/6/25:12:06:55 Administrator WIN7ULT64BIT1 Allied product is not found2013/6/25:12:07:25 Administrator WIN7ULT64BIT1 Install Autodesk AutoCAD® Civil 3D® 2014 Language Pack Failed Installation aborted, Result=1603
*Expert Elite*
rkmcswain
Message 4 of 7 (1,086 Views)
06-25-2013 11:16 AM in reply to: MEK_EST
Active Member
Message 5 of 7 (1,069 Views)
06-25-2013 12:34 PM in reply to: rkmcswain
Yes I saw this one but this refers to uninstall or a bad install so the program will show up in the fix. I tried but the install I am attempting will not show up for the fix.
Tried these too
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
To say the least I am bad need to get this resolved and I haven't heard back all day from Autodesk Subscription help starting to feel they forgot me.
*Expert Elite*
rkmcswain
Message 6 of 7 (1,063 Views)
06-25-2013 01:06 PM in reply to: MEK_EST
Sorry, wish I could help some more.
You never know how resourceful people are, so I always try to at least lead them in the right direction. Obviously, you've been there, and done that :-)
*Expert Elite*
jmayo
Message 7 of 7 (1,062 Views)
I just went through a bunch of nonesense trying to get 2012 and 1014 installed on a new PC. What I needed to do was unistall .Net4.5, install .Net4 (this was more for 2012 I believe), then I had to use Windows update a few times to get .net4 updated. After this I was able to install 12 but not 14. I then installed .net4.5, Windows  update again (3 times I think) and then I was able to install 14.
Note the common theme of having all .net updates installed.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
